ATIS/SIP Forum IP-NNI Task Force
 View Only
[nni] IP-NNI TLS Subgroup has been canceled
  • 1.  [nni] IP-NNI TLS Subgroup has been canceled
    Posted 7 days ago
    The event IP-NNI TLS Subgroup on 08-20-2026 has been canceled.
    Please note that to remove the meeting from your calendar, you may need to open the email, open one of the attachments in the email, select "yes" when asked to add to calendar, and then select "remove from calendar". If this does not work, you may need to manually remove the meeting from your calendar.
    If you have any questions, please contact:
    Anna Karditzas - akarditzas@atis.org
