The event IP-NNI TF Messaging Subgroup Meeting on 05-22-2026 has been canceled.
Please note that to remove the meeting from your calendar, you may need to open the email, open one of the attachments in the email, select "yes" when asked to add to calendar, and then select "remove from calendar". If this does not work, you may need to manually remove the meeting from your calendar.
If you have any questions, please contact:
