ATIS/SIP Forum IP-NNI Task Force
 View Only
  • 1.  IPNNI-2024-00045R001.docx uploaded
    Posted 09-12-2024 06:55:00 PM
    Submitter's message
    This revision updates Figure 6.2 to remove reference to OCSP, removes text I missed earlier related to OSP using valid base PASSporT to set shaken attestation level, and cleans up some editorial issues.
    David
    Date: Thursday, September 12, 2024 at 1:01 AM
    To: David Hancock
    Subject: [EXTERNAL] ATIS/SIP Forum IP-NNI Task Force : IPNNI-2024-00045R000.docx uploaded
    Submitter's message
    Propose the following updates to ATIS-1000092.v002 draft baseline:
    1) Remove the procedures that say an OSP authentication service may use the presence of valid base PASSPorT signed with a delegate cert as evidence that "A" attestation criteria have been met. Instead, the OSP should simply assert shaken attestation level as specified in ATIS-1000074.
    2) Remove support for OCSP.
    3) Added support for draft-ietf-stir-certificates-shortlived, including support for “x5c” in the PASSporT protected header.
    -- David Hancock
    -- David Hancock
    Document Name: IPNNI-2024-00045R001.docx
    Description
    Proposed updates to ATIS-1000092.v002 draft baseline.
    Download Latest Revision
    Public Download Link
    Submitter: David Hancock
    Group: ATIS/SIP Forum IP-NNI Task Force
    Folder: 2024
    Date submitted: 2024-09-12 22:55:24
    Revision: 1
  • 2.  RE: IPNNI-2024-00045R001.docx uploaded
    Posted 09-12-2024 09:56:00 PM
    Correction – I meant to say it updates Figure 6.1, not 6.2  (off-by-one error).
