It was great seeing everyone last week and I hope everyone had safe travels back home!
Below are the Action Items captured at INC 192. Please review them and let me know if you have proposed edits by COB August 27, 2025. Otherwise, I will post to AWS as is.
Tara Farquhar (NANPA) will investigate if there are any available NPAs that can be designated for 5XX use. (AOB)
Connie Hartman (iconectiv) will review the OCN definition for all INC documents. (AOB)
Connie Hartman (iconectiv), Sharon Pistachio (Verizon), and Tessa Whiteside (Telnyx) will bring in an Issue to create a single glossary and review consistent acronym use and inclusion in the glossary. They will subsequently submit a contribution and create a draft glossary with the TBCOCAG's terms and definitions. (AOB)
Kayla Goldfarb (ATIS) will draft a list of the active INC guidelines which includes the date of last time they were updated for participants to review at INC 193. (AOB)
Participants need to review the list of INC guidelines that Kayla Goldfarb (ATIS) will draft and prioritize which documents need to be reviewed by INC 193. (AOB)
Allyson Blevins (Sinch) and Tara Farquhar (NANPA), Melinda Yost (Boost Mobile) will work on a PIM for the NPIF meeting to discuss Issue 973 by INC 192. (973)
Kayla Goldfarb (ATIS) will remove Phillip Linse (Lumen) and Dyan Adam's (Verizon) contributions under Issue 986 for the INC 193 agenda. (986)
INC Participants are to review the timing of the public notifications related to the assignment of CO Codes from a new area code. (986)
Tara Farquhar (NANPA) will move Section 6 of ATIS-0300061, NPA Code Relief Planning and Notification Guidelines to be included in Section 5. It will be inserted as the new Section 5.3 at line 295. Ms. Farquhar will also make edits to correct the document's numbering and rearrange the order of the listed alternatives in Section 5. (986)
Tara Farquhar (NANPA) will go through the ATIS-0300061, NPA Code Relief Planning and Notification Guidelines and determine when "code" should follow "NPA". (986)
Tara Farquhar (NANPA) will rework Section 6 of ATIS-0300061, NPA Code Relief Planning and Notification Guidelines to remove any language that does not apply to glossary definitions and ensure consistency in the document. (986)
INC Participants are to review timing of the public notifications related to the assignment of CO Codes from the new area code. (986)
Tara Farquhar (NANPA) will bring a contribution to streamline and update Section 4 of ATIS-0300061, NPA Code Relief Planning and Notification Guidelines for necessary updates with text related to NPA Code Relief Activities in the TBCOCAG with the intention of removing duplicative text from the TBCOCAG and limiting the text in TBCOCAG except for CO Code/Thousands-Block assignment responsibilities/actions during NPA Relief. (986)
Tara Farquhar (NANPA) will bring a contribution to separate protected CO Codes and protected Routes in Section 5 of ATIS-0300061, NPA Code Relief Planning and Notification Guidelines. (986)
ATIS will investigate how to make the master glossary publicly accessible. (987)
Tara Farquhar (NANPA) will put the TBCOCAG terms into a single document and draft a contribution. (987)
John Nakamura (10x People) will identify what are the appropriate edits to be made to the ATIS-0300065(2024-10), Location Routing Number (LRN) Assignment Practices' baseline for review at INC 193. (987)
Tara Farquhar (NANPA) will investigate options for being able to accept inter-company transfers via the mass modification process. (992)
Tara Farquhar (NANPA) will investigate providing the 5-year average forecasted historical analysis and 5-year average actual historical analysis for both 5XX NPA Exhaust and NANP NPA Exhaust in addition to the current average future forecasted analysis. (993)
Tara Farquhar (NANPA) will draft a baseline document and create a matrix indicating which sections of the current TBCOCAG will be added to the Section in the baseline document for INC 193. (1000)
Service providers are to internally review INC-2025-00103R000 and suggest other solutions quantify Issue 1003, Proposal to Reduce Rate Center Order Denials via Optional Immediate Code Assignment. (1003)
Please let me know if you have any questions.
