INC - Industry Numbering Committee
 View Only
"Farquhar (NANPA) will inquire internally about a previous exception made for over contaminated blocks included in the TBCOCAG." Modified
  • 1.  "Farquhar (NANPA) will inquire internally about a previous exception made for over contaminated blocks included in the TBCOCAG." Modified
    Posted 07-31-2024 06:40:00 PM
    Action Item Subject: Farquhar (NANPA) will inquire internally about a previous exception made for over contaminated blocks included in the TBCOCAG.
    Item Number: #0097
    Description
    Tara Farquhar (NANPA) will inquire internally about why an exception was previously made for over contaminated blocks and where the authority for INC to include this within the guidelines came from.
    Owner: Ms. Tara Farquhar
    Status: Closed
    Priority: Medium
    Due Date: 2024-08-13
    Comments
    Ms. Tara Farquhar 2024-07-31 10:40 pm UTC
    INC Issue 585 added the language: “MTE and Utilization requirements are waived when accepting a block that is over 10% contaminated.” The issue Activity Log did not capture any discussion regarding concerns over INC’s authority to implement this change or INC having requested authority to make this change.
    INC Issue 715 added the language: “If an SP donates a block in error with more than 10 percent contamination, the SP may retrieve the block from the PA, provided the block is still in the Industry Inventory Pool. To retrieve the more than 10 percent contaminated block, the SP shall send an email to the PA with an explanation for the requested block retrieval.” The issue Activity Log did not capture any discussion regarding concerns over INC’s authority to implement this change or INC having requested authority to make this change.
    The Over-Contaminated Exception buttons were added as a result of Issue 715 and were part of Pooling CO 23.
